air cleaner and pipes question
I have an 05' night train thats fuel injected, currently i have a stage one filter and download with drag pipes.
My question is i wanna change to the heavy breather kit and V&H 2-2 big radious pipes, and need to know if im going to need to get the fuel-pak right away or not. i plan on taking the baffels out so im guessing the download thats in the bike now should be ok being that my pipes will still be straight through and i dont think there will be much of a differance in the air its sucking in.
correct me if im wrong please
You don't "need to" but you should. The factory download that's in there will be okay and you won't blow up. I have no direct experince with the V&H fuel-pak so I can't comment.
All that being said, a Power Commander will give you much better throttle response, cooler running and better performance.
i have heard good things about both programmers, i just said fuel-pak cuz i was goin with V&H pipes, i will get one as the next thing for the bike after the pipes, but just a bit pricey to snag em both at same time, just wanted to know if it would be ok "temporarily". actually bouncin a few dif. pipes around in my head also, but still with no baffles until i get a programmer
