LED headlamp daytime visability
this shootout of LED Headlights explains alot about the differences between the narrow more focused beam of the HD-LED, & wider beam of the Truck-Lite LED for much better visibility during daytime riding, ( i've got a Truck-lite Led headlight, along with a modulator being shipped & will install as soon as it arrives )
http://www.lrsanitary.com/0/leds_update.pdf
I would agree with the writers also. I have the 5-1/4" H-D LED, and my buddy has the Kury 7" & both are MUCH better than stock, but do have a different spread of light.
As is stated in the article though, the H-D one does switch lamps from low to high...I wonder if there is any way (or detriment to) have both run when on high?
Awesome article...thanks for sharing.
Info@wickedwarnings.com
I drive in the day with the high beem on only. It aims higher and in the bright daylight it can be seen better. I want to do the wiring so that the passing lamps stay on all the time but the dealer says that will void warranty. I'm not real happy with the lights in the day for others to see me. At night, they are excellent!
It's very easy to do, all you need is a dioed. Email me if you want you low to stay on when high beam is on and I can send you the parts and a diagram. I can even make it plug and play for you guys. Very easy and super cheap.
