2004 rear fender wire channel
You may be able to obtain it from your Dealer. When I installed my repainted rear fender I used a coil-like plastic sleeve, which completely encases the wiring. This casing was attached to the inside fender with E2000 glue, commonly known as 'Goop'. Available from Home Depot, this product has tremendous adhesion properties when dry, yet remains semi-flexible. I've glued LED accent lights onto the fenders, fork struts and inside the belt guards. To remove, you've got to slice it with an X-acto knife.
Most Auto Zones, Advanced Auto or electronic supply houses carry that plastic sleeving in various diameters.
Here you go..
You can find these on ebay for about 7 bucks.
http://www.harley-davidson.com/en_US...ts/-J01722.pdf
conduit
Here you go..
FBFletch
12-23-2020 02:17 PM
