Dead in the Water.
Old 07-05-2011 | 04:55 PM
mike06train's Avatar
mike06train
Default Dead in the Water.
I posted alittle while ago that the bike went dead and I thought it was the ignition switch. Turns out its fine. Some people said the main breaker and to let it reset. Well I got it running and went for a ride till midnight. Went to leave for work at 7:30 the next morning. Turned the switch and had power & the fuel pump cycled. Hit the start button and it cranked once, then clicked like the battery was low then I lost all power again. I got nothin'. No lights, pump, starter, squat!! If anyone has any ideas I'd be greatful. I tested the battery and I have 12.49 volts. I have the battery tender on it and the light is green. It's been down 4 days now so I don't think the main breaker has to reset. Just looking for some insight before I give up and send it to the shop.
Old 07-05-2011 | 05:29 PM
Tom84FXST's Avatar
Tom84FXST
Have you taken a wrench and checked the battery terminals for tightness...that is the problem 90% of the time.
Old 07-05-2011 | 06:31 PM
Blk and Chrome's Avatar
Blk and Chrome
sounds like a loose or poor ground, ck all of them and the batery connections
Old 07-05-2011 | 09:54 PM
mike06train
I'll start there tomorrow. The cables felt tight but I'm gonna double check.
Old 07-05-2011 | 10:14 PM
xraybox's Avatar
xraybox
Does your headlight dim out, is the battery good (passes a load test) Don't just check the battery connections, check ground to frame (2+), positive to starter, also rock the kill switch back and forth while holding the starter button in, it might be dodgey.
Last edited by xraybox; 07-05-2011 at 10:15 PM. Reason: typo, removed extra is "in is the battery is good"
Old 07-05-2011 | 10:21 PM
mike06train
I have no headlight. It dosen't dimout. I just have nothing.
Old 07-05-2011 | 10:51 PM
FLSTF2010's Avatar
FLSTF2010
My last bike (sportster) did the same thing. Was dead except had it on a charger and it appeared charged and tested 12+ volts. Looked normal. Put in a new battery. Bike fired right up. Try a different battery also!!!
Old 07-06-2011 | 01:01 AM
Rakthi's Avatar
Rakthi
+1 on that, happened to me too. Battery tested OK but didn't hold a charge.
Old 07-06-2011 | 03:24 AM
caaraa's Avatar
caaraa
That is a bad news.
Old 07-06-2011 | 03:27 AM
kkiley's Avatar
kkiley
If it's not a bad ground or loose cable, I'd suspect your battery is shorting out a cell under load. Get it tested....
