Seems shakey or maybe its me..
Old 06-24-2011 | 02:36 PM
Hot Rod King's Avatar
Hot Rod King
Originally Posted by cjwanner2000
32 is not enough air pressure. i run 40 in front and 36 in rear on both my bikes and they run great. excellent traction in the twistys.
For the stock Dunlops ?? I should boost it up closer to 40 ? I'll give it a try and see if that helps. Otherwise, I'll have my indy shop check it out
Old 06-24-2011 | 02:52 PM
2deuceguy's Avatar
2deuceguy
i've always ran 40 in the front and never had a problem. good tread life and traction. i put my third front tire on at 25,000. it runs very straight and smooth
Old 06-25-2011 | 02:32 AM
Reb DEATH's Avatar
Reb DEATH
If it continues, it is probably your fallaway. Just need to adjust it. There is another thread about the "wobble" somewhere here in softails.
Old 06-25-2011 | 08:27 AM
fcsallan's Avatar
fcsallan
I had this a few weeks ago and it drove me nuts. Since it couldn't hurt anything I put the grease gun on the neck and started giving it a few squeezes. 15 squeezes of the handle before I noticed any movement at the lower seal. Once I cleaned it up I took it for a spin and no more shake. I watch that a bit closer now since I do my own service so either the last service I forgot to add grease or it has been squeezing out a bit more than I thought. I doubt that since there was no added grease on the front of the bike.
Eldon Laue
2014-2023 Touring Models
09-05-2015 12:23 PM
kingnothing71us
07-26-2015 05:51 AM
Cory81
12-04-2013 08:49 AM
Mo.Rob
06-08-2013 12:50 PM
vulhalla
09-06-2007 05:04 PM
Quick Reply: Seems shakey or maybe its me..
