big bore kit
Ok thanks for the info its a big decision for me seems like most people is going with the se kits what u guys think on the s&s kits
The 211 is a great cam. It comes on a little later than some other cams but will give you a lot of usable power. If you have worked on cars before an engine build on a Harley should not be too difficult. There is nothing like the pride you get from doing it yourself.
As far as what kit, there are a lot choices. I did the Screaming Eagle 95" kit so I would not have to wait for my cylinders to be bored or anything else. I kept me heads stock for now as I want longevity on my engine that already has a lot of miles on it.
I run a 203 cam which com,es on earlier but does not give as much power up high. fI am going to be digging into my cam chest again this week as I w2ill be adding the newer Hydraulic style tensioners and bigger oil pump that my older (2002) bike lacks. Assuming my cams look fine I will reuse the same ones.
If you did the cams yourself you can do the big bore yourself no problem.
Drew
Drew
I had my cylinders bored, headwork, and piston reliefs done by Short Block Charlies in Tempe, AZ. He optimized my the build and my S&S 510G cams by decking the heads to get the proper compression ratio. After receiving my parts back, I re-assembled my engine and have over 50K miles on the 95" build.
