Painting Primary Cover: New Gasket?
Pull a gasket .... replace a gasket. But....you are getting ripped off at $35 ...Google Surdyke ... call em .... order one. Or go to another dealership ... $15 tops.
Really now. Ok, school me on why not. I've used that stuff for over 30 years on all types of bikes and NEVER had an issue. I also did not say to substitute it for the gasket, although that can be done too, I said to add a thin bead to the old one as insurance.
We used permatex gasket sealer in the 60's and 70's .... on stampef steal valve covers ... cork gaskets .... and iron heads. Tolerances were crap then .... the thin steel head covers would warp ... and gasket material was for shtt. None of that is true today. If you have good mating surfaces that have not been damaged .. there is NO need for permatex sealant ... and it can do more harm than good. Permatex makes a host of other products I use everyday ... like antiseize paste etc.
My opinion .... I am not insulting you .... nor do I intend it to be an attack on you it your experience. Just my 40+ years of wrenching on gas and diesel engines.
Jeepers ... first off. Don't take it personal ok. These forums are mostly opinions ... you got yours ....I got mine. Now ... back to why not use permatex. 1. Even if you are sparing ... some of it will ooze into the case causing flakes that get all over the place. 2. The stuff WILL plug oil holes. 3. If it hardens and sticks ... people will use metal scrapers to remove it ... inevitably marring the AL mating surface.
We have used that stuff on engine cases on Shovels, EVO's, and Pans for years w/o any sort of engine failures. I've seen plenty of cases that were pitted and chipped where a gasket could never seal it. But with the use of permatex it got into those crevices where a gasket couldn't therefore sealed the leak.
Agree on todays metals and surfaces being better than the past, but there is always someone using a prybar, screwdriver or other tools as means of scraping off gaskets and marring those surfaces, which unfortunately usually result in a "not so flat" surface anymore.
I do agree that in most cases to use a new gasket on anything that requires one. The new gaskets todays such as Jims come with a nice bead of silicone impregnated in them to insure no leaks.
But in a bind when no new gasket is readily available, there is no reason to not use permatex, as instructed.
I too wrench on everything from Briggs motors to diesel's, but will say when it comes to diesels all bets are off for silicone as gasket makers!
It's all good. I never took what you said as a personal blast but mine was my own opinion as is yours too. Ride safe my friend!
I just had my primary cover powder coated and didn't have to change the gasket. it hasn't leaked a drop yet either and it has been about a month. i say try it. if it leaks, you can drain the fluids, put the gasket on then, and put the fluids right back into it. just make sure you put the fluids in a CLEAN container.
