Stressed about ape install
Old 06-16-2011, 08:22 AM
rrambo's Avatar
rrambo
rrambo is offline
Originally Posted by beasleyiv
You do have an FSM, right?
service manual? I've got a 2010 service manual in pdf... it's a pita to find anything though.. probably going to order the 2011 in paper today...
  #42
Old 06-16-2011, 08:25 AM
Reb DEATH's Avatar
Reb DEATH
Reb DEATH is offline
Originally Posted by rrambo
one thing I hadn't factored in was needing to remove the gas tank.. that seems like a PITA...
Perfect time for a 2 or 3 inch lift kit Bro!
  #43
Old 06-16-2011, 08:29 AM
beasleyiv's Avatar
beasleyiv
beasleyiv is offline
Yeah, ditch the PDF and there are wiring differences between '10 and '11 that justifies the right manual.
  #44
Old 06-16-2011, 08:46 AM
Dissociative's Avatar
Dissociative
Dissociative is offline
before you decide where to cut your factory harness to add to it...
think about where your cuts will end up inside bars...having joints right in a bend SUCKS....cut carefully for the joints end up in the flat spot of the bars.
stagger your joints....and get some expandable sleeving from a radio shack or frys as it slides through bars like butter with wires inside..
also i got some clear wire pull lube from home depot and it helped a lot.
  #45
Old 06-16-2011, 08:47 AM
Reb DEATH's Avatar
Reb DEATH
I'm ordering my crap now for an "off season" install because if I screw something up then I'll be down for a few weeks while the parts come from the States. So, I'll have no pressure and a few months. The riding season is only about 6 or 7 good months for me here anyway.
  #46
Old 06-16-2011, 10:33 AM
Ash16's Avatar
Ash16
Ash16 is offline
It's not too bad. Just take your time.
  #47
Old 06-17-2011, 01:29 PM
AjAnd3rson's Avatar
AjAnd3rson
AjAnd3rson is offline
Check your PM's bro.
Looks like we will be installing the same apes on the same bike in the same state on the same damn weekend.
  #48
Old 06-17-2011, 02:08 PM
rrambo's Avatar
rrambo
rrambo is offline
Default and it begins
As soon as the namz extensions come in I'll be good to go.. went ahead and ordered the 2011 fsm too.. it's been shipped.. not sure about the extensions..
the rest was delivered today from drew... their packing is awesome by the way.. no way anything would have gotten damaged in shipment..
  #49
Old 06-17-2011, 02:26 PM
AjAnd3rson's Avatar
AjAnd3rson
Nice dude.
I see you went with the 1" risers.
I had to go with the 3"
Then again I'm 6'7".....
  #50
Old 06-17-2011, 02:36 PM
tattoofever's Avatar
tattoofever
tattoofever is offline
i used a kit from dennis kirk it was like 80 bucks or so but it had all chrome switches and about 4 ft of wires all color coated and covered with the heavy black outer cover just cut to the size you need i was able to make all my connections outside the bars just incase i ever have a connection issue all i have to do is lift the tank
Quick Reply: Stressed about ape install
