Stressed about ape install
The biggest issue could be if you don't have as much experience wrenching on your bike...you'll run into problems that'll take a little longer to fix...definitely nothing earth-shattering.
Start early, take your time, stay slow on the beers until you see the finish line.
You don't have to remove the tank. Remove the seat, remove the rear tank bolt, remove the front tank bolt, remove the fuel line quick disconnect from tank, slide tank back.
The hardest part will be the clutch cable. Get some BIG snap ring pliers and you'll be set.
Thanks guys.. and thanks to Drew for helping me pick everything out and get it ordered... just how big do the snap ring pliers need to be for the clutch cable??? I've got a pair but they aren't the highest quality.. and the fuel line disconnect.. other than telling me to RTFM, how do you disconnect it?
Although they are right, this job can be done with the tank on, it is only a few more minutes to empty the tank and pull it off.
After you do it the first time and realize how easy it really is, you will pull it off without thinking for future jobs. Like all jobs on these bikes the first time is the worst because you don't know what you are getting yourself into, but once done you will have the pride of a job well done.
![Smile](https://www.hdforums.com/forum/images/smilies/smile.gif)
I have pulled and slid the tank. I will slide it any day over pulling it. Yeah, pulling it isn't hard, it's just messy.
As for the quick disconnect, pull up on the collar and down on the fuel line. Have a rag to absorb the little bit of gas that comes out.
I have regular snap ring pliers, it was a pain. That is the biggest snap ring I've ever dealt with. I had to use the pliers with a screwdriver to get it off/on.
I used what I think are regular size snap ring pliers - little bit smaller than lineman's pliers - and it was fairly little effort to get the retaining ring off. Beasley, do you have really small hands?
J/K
rrambo, if you're not worried about the wiring, you shouldn't have too much trouble with the bar install. That's the part that I fcked up.
![Big Grin](https://www.hdforums.com/forum/images/smilies/biggrin.gif)
