2007 deluxe tail light problem
Old 06-16-2011, 07:04 PM
Sgt_Jim's Avatar
Sgt_Jim
Sgt_Jim is offline
this happened to me when i installed my new bars..it's 1 of 2 things if you've checked the bulbs...
1) You have a pinched wire in the housing that's causing a short
2) Your leads in the jack under the gas tank aren't making a proper contact, or are stretched too far apart..
for me it was the jack under the gas tank
Old 06-16-2011, 08:02 PM
3itodd's Avatar
3itodd
3itodd is offline
where is the module located?
Old 06-17-2011, 12:14 PM
95yj's Avatar
95yj
95yj is offline
On most Softails it's under the gas tank mounted between the frame members.
Old 12-17-2013, 05:02 AM
EzRussSDMC's Avatar
EzRussSDMC
EzRussSDMC is offline
Had the same problem with mine. I put better bulbs that weren't from the stealer and it stopped
tafdeluxe
05-17-2019 09:12 AM
Jetfever
05-31-2015 07:13 AM
jokr
09-02-2013 02:44 PM
flhxkiller
08-27-2012 04:51 PM
snowyhog
09-26-2006 12:40 PM
Quick Reply: 2007 deluxe tail light problem
