I bought a strutless fender for my 05 Nightrain from DNA and am having trouble figuring out how to mount it. Basically the width of the fender mounting points isnt wide enough to cover from side to side because of the horns. Any ideas?
Yeah pretty sure Imboden is right on the older bikes the horns have to come off, but i would check with the fender makers, or a Harley dealership before you get the hacksaw out.
It is the 180 rear fender. 11 inches wide. I knew I would have to cut off the horns but it is to wide and th base of the horns. I'm prolly going to have to grind the sides down. Darn.
11" between the mounting points is for a 99 down frame...99 -2006 is 11.75
A little more research before buying would have helped you.
These strutless fenders involve a LOT of fab work. Grinding, welding, etc. You can't just pop it on the bike. Even with '07+ bike which have the removable horns, the fit has to be exact.
I speak from experience. I bought this fender off of Demons Cycle and got burned.
