Help!!! Stuck between A bolt and hard place
use heat gun
With heat gun apply heat to shock boss of swingarm, the locktite will loosen up and bolt will be easy to remove. HD has some powerful loctite and when you reinsert the shoulder bolt to install the shotgunshock, be sure to apply red locktite to bolts. Thanks for using shotgunshock.
Check this thread out, Kiwideuce did a great tutorial with pics on how to lower a softail cheap... read thru and maybe you will get some tips on the bolts...
good luck
ps... click here https://www.hdforums.com/forum/softa...nty-bucks.html
good luck
