backfires on startup
Could be a number of things.
Plugs, the way U start it or even how U shut her down, even the tune.
I've read in here sometimes those that use the kill switch have a backfire on starts.
Also those who rev is a few time before shutting her down get it.
Plugs may need replaced.
Tune may not be on the spot. Seems like those with The PC - F/M have it often. If so might need to tweet it.
Also might read through some of these to see if it helpsl
http://www.google.com/search?source=...w=1271&bih=628
I have had a backfire on startup just 2 times on my FI Heritage. Seems I narrowed it down to 2 things. Shutting it down quickly and not letting it settle at idle for a second first, especially when hot, and hitting the start button and expecting it to fire right away like it usually does, only to have it crank over a time or two, but I already had let off the starter button. That will get it to backfire every time. I think it pumped enough fuel to start, just didn't fire, so next fire up right away had extra shot of fuel. Again, only when it is hot.
Mac daddy 103
27
08-07-2016 02:09 PM
texasmail1962
08-07-2013 03:13 PM
