How much decel pop is normal with Samson?
Old 06-06-2011 | 09:48 AM
kzoo's Avatar
kzoo
My 04 Heritage with SE II and SE A/C pops a bit on decel. I usually just decel slower or give it a touch of throttle and it goes away. I dont mind it.....Hell, I wish it would blow flames!!!
Old 06-06-2011 | 09:55 AM
Malingerer's Avatar
Malingerer
39 non baffled cholos with PCV from Fuel moto and a Carlini High Roller A/C.No decel pop at all.
Old 06-06-2011 | 02:09 PM
H-D DAD's Avatar
H-D DAD
I was thinking about putting 33" on my heritage as well. That would be awesome if you posted pictures.
Old 06-06-2011 | 02:44 PM
ghostrider69's Avatar
ghostrider69
I have 39" cholos with stock cleaner and no tuner and I get an occasional pop on decel but mostly it's a burbling sound. It sounds damn good when you are engine braking. Sounds like an old chevy truck I used to have that had a standard transmission and dual glass packs. Or as I have said before and old hot rod flat head with straights.
Old 06-06-2011 | 05:29 PM
alika808's Avatar
alika808
hey bro do u have any type of tuner? or are you jus running straight cholos and thats it?
Old 06-06-2011 | 06:09 PM
ghostrider69
I am just running straight 39" non baffled cholos and that is it. As long as you are just doing exhaust there is no need for a tuner. The modern computer can and will make small adjustments to the air fuel ratio.
Old 06-06-2011 | 08:06 PM
CountryD's Avatar
CountryD
Ive got 33's too. I ran mine with stock cleaner and no tuner, had some pop, but now I have a cleaner and tuner, and I have no Pop at all, maybe a "burb" every once in a while, but thats it.
Old 06-06-2011 | 08:24 PM
cpiad's Avatar
cpiad
Account Closed
Originally Posted by arrowslinger1980
Just picked up my new Heritage and i had them put on 33" samson dual fishtails and a SERT. I am getting quite a bit of decel pop. I'm wondering if i need to do more tuning or if everything is cool.
thanks fellas
Does no harm...but annoying. Yes...more tuning is needed. Don't know squat about SERT...but on my Tmax....I looked at RPM when POP starts and stops. Then I richened up AFR from 0 rpm to point where it stops...low end. Then Tmax has a setting that cuts decel fuel from high RPM point to low point. Now I only get occasional POP. If SERT has similar ability...try my routine. It popping cause mixture is lean...and flame front leaks past exhaust valve. If you can richen up low end mixture and cut injectors off at POP start and stop RPM...that'll get it.
Old 09-16-2012 | 11:50 PM
Fabrikator's Avatar
Fabrikator
sorry to bring up this old thread.. but I installed my 39" unbaffled cholos, and a Ness big sucker stage II AC, and got the PV from fuel moto.. I told them what I had (just the 2 mods above) on an otherwise stock 96".. before and after loading their tune, I am still getting quite a bit of decel popping. and to me it seems quite rich. after riding when i park it, theres quite a bit of raw fuel smell, enough to fill the garage. I have had this problem in the past before the installation of the new AC and cholos.. but it kinda went away on its own. (after the dealer said they couldnt find anything wrong).. but its obviously doing it again.. weather its related to the tune or not.
ideas?... esp for the decel pop, could anything else be causing it, other than an improper map?, Id like to hear some opinions before I call up fuel moto to see if they have another tune I can use.
Thanks in advance
Old 09-17-2012 | 12:18 AM
oppirs's Avatar
oppirs
I can only go by mine. I have them Samson's, but I look at my ride as old.
Try 2-1 will work wonders, looks awkward but works great!
Bringing up a old thread is good, in your case!
Not too many Samson threads.
