Heated Grips and internal wires
Hi Guys,
Has anyone installed heated grips with the wires running internally?
I have a 2010 Fatboy and the bars are all internally wired, and I have installed Heat Demons but they don't heat enough. I think it is because I am running the Glue-less WillyG grips and there must be an air gap between the grip and the bar. The temp here is about 12DegC and they are no where near warm enough.
SO... if I get some HD heated grips, can I run the cables internally? The info on the product states "Not compatible with internally wired bars" and I just want to see if anyone has done this.
Cheers
Mongrel
Cheers
Mongrel
I installed a set of Heating elements in my bars made by a company called "PollyHeaters." They are internally wired. In fact I don't think you can externally wire them, or at least it would be very difficult to do so.
I think that they are actually made for Snowmobiles but they definitely work. They have two settings: Low and High. High will melt the grips (No $h!t) and with low you'll have to turn them off periodically or it'll get warmer than you'd probably care for. I've ridden in 0 C to 5 C weather with these for hours, with no problem except that while the palms of my hands are getting quite warm (almost to the point of too hot), the back sides are getting a bit chilly.
Anyhow these things are $30 and the web site is http://www.pollyheaters.com/ph200.htm
I got turned on to these here on this forum so it's only fair that I pay this forward, as it were.
I have the Heat Demons, and they are internally wired... I wonder if they mean not compatible with throttle-by-wire?...
I've wired everything internally, and they work... at low temps, and highway speeds, they tend to not keep the grips warm.. my guess is, the bars act like a giant heat sink.
Still, better than nothing, and last longer than the HD grips. Added benefit, is I can change grips for very little $... Wiring is undisturbed.
BD
BD
i have harley brand heated grips. i ran all my wires run internally. both the heated grips and the controls. it works fine.
I asked my dealership why you couldnt run them internally. They said they do it all the time. So, it might be a cover your *** thing for the motor company. or maybe they dont want to deal with the wires once they are all run inside. it would make finding a short difficult.
bottom line, it works fine.
Stone
luv_my_harley
10-23-2010 08:27 AM
