Changing handlebar position
Old 06-02-2011 | 03:28 PM
kzoo's Avatar
kzoo
Default Changing handlebar position
Per a suggestion in another thread here, I would like to lower the position of my handlebars on my '04 Heritage to try to alleviate some tendonitis in my left arm. My manual has not yet arrived (Have not checked yet today) so I will ask.
Anyone with a manual for that year softail that can give me torq specs for all the bolts to move my bars (tilt them lower) I would greatly appreciate it!
Thanks in advance.
Old 06-03-2011 | 03:24 PM
95yj's Avatar
95yj
Never worried about torque specs for the handlebar clamp bolts. I don't even think my MoCo manual has them. Tighten them down evenly so that the top clamp isn't too far forward or backwards and get them tight enough so the handlebars won't slip and they won't come loose. I usually use an allen wrench instead of a socket. That way it's more difficult to tighten them too much.
Old 06-03-2011 | 03:55 PM
matt816's Avatar
matt816
I think its around 150ish inch pounds. I crank em down. They can move= scary on the highway.
Old 06-03-2011 | 03:59 PM
jed1069's Avatar
jed1069
As said before tighten evenly and tight enough you can jerk on the bars with no movement.
Old 06-03-2011 | 06:41 PM
jimmers1817's Avatar
jimmers1817
Specs for my 08 is to first hand tighten 2 front screws. Tighten rear screws 12-15ft lbs. Then tighten front screws same. I do mine 18-20lbs to be on the safe side. Never heard of anyone breaking them off from over tightening so I don't know if it's possible or not.
Old 06-03-2011 | 07:14 PM
fcsallan's Avatar
fcsallan
Never even thought about torque specs for risers. I've been doing this way too long.
Old 06-03-2011 | 10:53 PM
imboden's Avatar
imboden
can't find the specs in my 05' manual. took the time to actually get it out and look!! I know I've changed the risers on lots of bikes, and I've never worried about the specs. But....I've always used loctite too!
Derek_96
04-07-2018 01:07 PM
rs87277
06-18-2012 03:07 PM
RaceFace
09-20-2010 07:40 PM
Kapernicus
04-23-2007 05:14 PM
ny06fxdb
04-18-2007 01:56 PM
Quick Reply: Changing handlebar position
