Nacelle on 09 Fatboy
Before you yell, I did search but couldn't find the answer. I am kicking around the idea of putting a Nacelle on my bike. But, I have the bars and risers from a Lo on my bike now. All the info I see, shows changing the risers for a stock Fatboy, not the Lo. Does anyone know what is needed to put a nacelle on a Fatboy with Lo bars and risers. I'll keep checking, but figured someone here may have already done this. Thanks.
You only have to change the bars and risers if you want to use the riser cover that comes with the nacelle. There are other options to cover the top of the upper tree to finish it off and keep your bars. Something like this http://www.cyclevisions.com/chrome/cover-up/
works pretty well.
works pretty well.
If it is anything like the nacelle on the road king, you have to either run really short, like 1" risers or get a different cover for the nacelle. The cover actually covered the risers on the road king and gave the appearance that the bars came out of the nacelle. The make a top cover though that has two holes in it that allow the use of either TT style bars or longer risers.
