Crappy cell pic, but the 2 into 1 bassani is on the Rocker
It's a little quiter at idle then the BR's, but when you start working up through the RPM's, it's deep and throaty. Haven't stuck it on the dyno yet, but I can tell a difference from bottom to top end. I'll get some good pics of it when I get time
Make sure you don't have the muffler bracket on upside down.
I put mine on upside down the first time.
The rocker bracket is different from the regular softail bracket. Can't put it on upside down, but you could flip it around backwards. However, if flipped around backwards, no way in the world it would line up. And it is low, but I'v got the shotgun shock slammed in the pic.
