Transmission Cover - Silver to Black
Old 05-19-2011, 05:28 PM
Sgt_Jim's Avatar
Sgt_Jim
Sgt_Jim is offline
The wrinkle Black in Powder Coating (at least at my PCer) was called "Hot Rod Texture Black"..
Keep in mind it's glossier than the engine because it was fresh powdercoating and i hadn't cleaned the engine yet.. and also keep in mind that it won't match the engine 100%, Nor will the Harley Wrinkle Black one that you can buy.. my dad has that one on his NightTrain and you can still see an apparent difference in the blacks.
Btw, the entire silver part is called the "Primary Cover"..the black circle cover is called the "Inspection Cover" and if you go to the other side of your bike, the thing that says "Six Speed" is your transmission cover
Old 05-19-2011, 05:55 PM
4-Banger's Avatar
4-Banger
4-Banger is offline
Or round is Derby - Oval is inspection - on older TCs
Old 05-19-2011, 06:00 PM
TNB's Avatar
TNB
TNB is offline
My primary cover and derby cover may not match "100%", but I can't tell the difference. The photo on the prior page speaks for itself. The "circle cover" is also called the "derby cover". The "inspection cover" is the smaller rectangular cover plate on some of the primary covers. Mostly, found on the older bikes from what I've seen since the 2010-11 Lo's I've seen don't have an inspection cover on the primary.
Here's an entire thread devoted to "derby covers":
https://www.hdforums.com/forum/softa...ts-see-em.html
Here's a couple of links to an "inspection cover":
http://www.cyclesolutions.net/index....dson%20SOFTAIL
http://www.demonscycle.com/Other-Sup...77312-2-1.html
Old 05-19-2011, 09:24 PM
bazzhed's Avatar
bazzhed
bazzhed is offline
sometimes you can find used ones on ebay for pretty cheap. any twin cam 96" from a softail or dyna with forward controls should work. fat bob comes stock with black...as does the xbones and night train i believe.
i picked one up at a dealership for 20 bucks. brand new take off. every once in a while dealers need to get rid of old take off parts that they accrue throughout the year and they will have a "flea market" or "swap meet" in their parking lot. best place to find good take off stuff. get in tight with your local parts guy and find out when they are having one.
Old 05-19-2011, 09:48 PM
brettnbama's Avatar
brettnbama
brettnbama is offline
I have a set from a Fat Boy Lo that I had PCed black on my bike. My guy here asked me if I wanted wrinkle black or texture black.. I told him I wanted it to match the case. He said that was texture black. Thats what he used and it is an absolute PERFECT match.
Old 05-20-2011, 01:26 AM
dcgray2's Avatar
dcgray2
dcgray2 is offline
I chose to have mine PC'd to match the Denim Black. I like it better than the wrinkle. And yes it looks different from the primary if your bending over looking at it. But it matches the tank and fenders perfectly.
At 60 MPH you can't tell it doesn't match the inner.
Old 05-20-2011, 01:52 AM
Detroit Iron's Avatar
Detroit Iron
Detroit Iron is offline
H
Thanks for pointing out the proper (or common) terminology of the parts.
ThrillKilla
05-03-2017 05:30 PM
cvaria
01-02-2017 07:23 PM
toastman
01-27-2011 07:58 PM
streetbobJB
07-11-2008 11:20 PM
Quick Reply: Transmission Cover - Silver to Black
