Checking Drive Belt Deflection
Old 06-04-2011, 10:59 PM
JIMSFBL's Avatar
JIMSFBL
JIMSFBL is offline
Yea, that's quite a first post, but it is a very informative one. Good to know! I've always marked the tensioners with a piece of tape, but I never thought of checking it with a string. Now I have to do that everytime or I will wonder from now on if it's in line with the front.
Old 06-05-2011, 06:32 AM
DaddyKnuck's Avatar
DaddyKnuck
DaddyKnuck is offline
Received 1,661 Likes on 946 Posts
I used to use the string technique, especially to square 4 speed trans/eng with open primary. Laser pointers got so cheap a few years back that I now use two of them. The 8' tubes wouldn't last very long in my shop either.
Old 06-05-2011, 07:32 AM
FroggyFatBoy's Avatar
FroggyFatBoy
FroggyFatBoy is offline
my dad taught me the string method yrs ago, and have used it on 4 wheelers several times over the yrs.. my dad being a semi mechanic and working for a family business they didn't have the money for a proper alignment machine.. he would align rear axles, frt ends, etc with a string and level..
my question on bikes is, how do you make sure the frt tire is perfectly straight ?
Old 06-05-2011, 09:20 AM
JIMSFBL's Avatar
JIMSFBL
JIMSFBL is offline
Why are light tubes used, do you know? It seems they would't last long as you said and that wouldn't be my choice of alignment either.
Old 06-05-2011, 11:48 AM
PPBART's Avatar
PPBART
PPBART is offline
My guess is near-perfectly straight, and not too expensive.
Old 06-05-2011, 12:12 PM
DaddyKnuck's Avatar
DaddyKnuck
I'd have to agree, straight and cheap. The lasers make the wheel alignment easy as well. I still prefer string or a flat piece of 1/2" tempered to align compensator and clutch basket.
Old 06-05-2011, 01:23 PM
fcsallan's Avatar
fcsallan
fcsallan is offline
I always used the drive belt. If the drive belt is tracking too close to the outer edge the wheel is slanted right, if it is too far to the inner edge it is slanted left, if it is in the center of the drive pulley you should be damn close to straight.
Old 06-05-2011, 02:26 PM
95yj's Avatar
95yj
95yj is offline
Originally Posted by DR. V-TWIN
Twist the belt with the bike on the lift and you should be able to twist it to a 45* angle.
Been using this one for years. It's amazing how accurate it is. Many times I've had someone using a tension checking tool and I've said, "Wait, watch this". Tighten it up till you can get 45 degrees. 90 is too loose and 30 is too tight. After setting it, I had them check with their tool and viola, perfect every time.
SiggerTX
08-15-2016 06:59 AM
clap
08-06-2014 12:19 PM
ridedaddy
07-31-2013 01:03 PM
big_e78
03-10-2010 09:33 PM
jbroughton
08-30-2006 01:03 PM
Quick Reply: Checking Drive Belt Deflection
