New cams
New bike probably won't need new lifters either, our wrench usually suggest's them if bike has over 15k.
didn't do mine, but though about it,, dealer had a winter special 2yrs ago, included, cams, lifters, oils changed and Labor, plus they threw in a free dyno tune when done... all for $875.
I just let them do it for that...
If you're still interested in knowing what to expect, look at the quick how to at the bottom of this page.
http://fuelmotousa.com/cams.htm
I have a FuelPak installed.. nobody seems to care for them around here.. but it seems to do the job.. VH has maps for my mods if I do a cam swap... I got the FuelPak out of necessity and low price.. if I do the cams I will probably eventually do the PCV from FuelMoto
You may have to replace the pushrods, depending on the cam you choose. It's because of the base circle on the cam. If you can and want to keep your pushrods, you have to get into the rocker boxes and lift the gas tank out of the way. Some guys figure at that point, I may as well take off the heads, have them re-worked and install one of the big bore kits or new pistons with their cylinders bored out. Throw in a thinner head gasket as well to up the compression. If you go with adjustables, you cut off your pushrods with a bolt cutter and reinstall the adjustables without having mess with the top end or take off the gas tank.Regardless, you'll need new o-rings for the tubes and some o-rings in the cam chest, gasket for the cam cover.
What he said ^^^^.......
Cutting the old ones and using adjustables cuts the time in half. It also allows you to adjust potential 'tics' out. It also makes any future work in the cam chest a hell of a lot easier because you don't have to go back through the rockers. That's the pros. The only con, in my opinion, is it's another $150-ish. But I think it's well worth the $$ to avoid the hassle of going through the top.
