Flashing blinkers - help.
05-13-2011, 10:53 AM
Ok, my boy just got a 2002 Deuce (carb). When he turns the ignition on, all 4 blinkers flash several times then return to normal. What does this mean? Thanks.
05-13-2011, 10:59 AM
mine does the same. hes got aftermarket kuryakyn signals right? I think a few blew on mine a while back, thats probably what it means. but i test the signals& brake lights from time to time and everything is still working fine.
05-13-2011, 11:20 AM
I was thinking the security system. Will it start?
Drew
05-13-2011, 12:21 PM
Stock signals and they work as they should, and it starts so I don't think it's security.
05-14-2011, 07:48 AM
Your emergency flashers are on,start the bike and push in both directionals at the same time,then release,that will shut them off
05-14-2011, 11:39 AM
Does it have an aftermarket ignition system? I run a daytona twin tec and it flashes when I turn the bike on...
05-14-2011, 12:08 PM
I'm not sure about the ignition - I'll have to check that one out. If this helps, they flash 6 times quickly then turn off - not slow flashing like the emergency flashers.
05-14-2011, 12:27 PM
I'm having signal problems on the left side, they dont work at all. But the right side also flashes 6 times fast when the ignition is turned on.
05-14-2011, 12:32 PM
The battery in the FOB is about to expire - 5 bucks.
05-14-2011, 01:06 PM
