Do I need a Fuelpak or something?
Hello all,
My 2011 Fat Boy Lo is in at the dealership getting some stuff swapped, including the exhaust. I am putting on the Vance & Hines Big Shots Staggered (black) exhaust with the quiet baffles/ Smartpartz baffles combo, and a Performance Machines Universal Super Gas air cleaner.
The dealership is installing this, but they never mentioned anything about some stuff I've seen mentioned here, like Fuelpak and Power Commander, etc.
Is this something you buy and add to the bike? Is this something I should look into? Which should I go with?
Thanks for any help!
Hello all,
If the dealer is doing the Stage I, they should automatically be doing the Stage I flash update to the ECM. I'd call them to see if it's included. Either way, if you decide to go with a FuelPak you'll need to know if it has the Stage I flash or not in order for V&H to send you the right map for the FuelPak.
Contact Jamie at fuelmotousa.com He will set you up with a Powercommander with the right map. I would go powercommander over the fuel pak because even if you convince yourself you will never do any more to the engine you never really know Then all you would need would be a new map. Fuelpak is not great for additional mods.
You don't actually need it, because the ECM of todays bikes manage the fuel just fine. I have the V/H 2 into 2 with the S/E A/C w/Stage I. I have NO popping, backfire or any issues at all. I'm very happy with it and would only add a PC V if issues of fuel management came into play.
I have a friend that also has a lo and has a PC V, but he had some popping on decel and that's why he got it. Both of ours are 2010's.
high iron
09-01-2008 11:54 AM
