dirty wheels
dirty wheels
Does anyone know if the rear wheel and sprocket (not profile) on my 08 NightTrain are clear coated. And do you have any suggestions on how to get them clean, they have been neglected for a while and stored outdoors. I have tried Colonel Brassy, Mothers power metal and they work a little but not the results I would like to see.
Thanks
Thanks
Hmmm... my wheels don't act like non-painted... you can polish them but I think you're polishing the paint, not the aluminum. There are spots on them that won't 'polish' out and it isn't from oxidation it doesn't seem. There is a surface variation like the paint is oxidizing, maybe.
My solution was to get a big pair of boss bags with the quick release. I pull the bags, wash the bike, and then put the bags back on. Wheels look good at 70 mph.
When I bought my 98 Sportster the wheels looked bad from the years of I wont say neglect but maybe just lack of real polishing over the years. It didn't matter what I used they just weren't gonna shine again.
I took them to Metal Master's and had them bead blasted then mirror polished. I also took them a used rear pulley to be polished rather than a cheap chrome liner.
I was told the rough cast area was just going to suck the grime up again if I didn't seal that area so I used Dupilcolor Primer, Wheel Paint and Clear to seal them....That was some 4 years ago and the wheel are still looking great.
Karsten
Karsten
Well I took all thoughts and suggestions and put together my own plan which worked out. Since I ride a Nighttrain I wasn't looking for a super shiny chrome look so I decided to try and use wd40 and steel wool to try and get a brushed look. But before I went that far I sprayed the wheel with wd40 and started using the Colonel Brassy on it and all the dirt and grime just polished away. I still dont understand one thing though the outside edge of the wheel looks like factory but the same process made swirl marks on the hub section. Thanks for everyones help.
Polished area are unsealed and easy to keep clean and shiny now.
Karsten
champ198
12-17-2010 02:50 PM
