C&C seat- what am I doing wrong
ok finally got around to putting on my c&c solo seat but I cant seem to get it on there right. I see it has the tab on the front that goes in like the oem one but it has a tab on each side that has a hole in the tab. Do those just slide in to the sides where it seems there is some space ? Or do I have to remove those bolts that are holding the chrome trim piece on the side and then slide those tabs on it ? It cant be that hard right ? Thanks
On the frame in front of the struts there are holes for the seat to bolt to the frame. These holes sometimes have plastic plugs in them depending on the year and model of the bike. My fatboy does not have the soloseat bolt to the fender so it bolts on the side. I had to get some bolts from the dealer to attach the seat. How does your stock seat attach and is there a hole in your fender for the back of the solo?
Drew
Drew
Drew
Drew
Does the fender have another hole in it at the back of where the solo seat would set? Maybe a plastic plug. Can you post a close pic of the side of the frame where the seat looks like it should bolt? From your sig pic it looks like the chrome trim piece you are referring to is actually the fender strut.
here is a pic of the chrome bolt thing I was saying and a pic of the underside of the seat
