It's a fake seat post, it just bolts in at the top to the frame under the seat and at the bottom to the transmission. It's only there to hold the coil.
Pic of mine removed
I used the Exile kit and moved it behind the rear splash guard. Also used the exile horn relocation kit. If you want a completely clean left side engine, I would recommend the coil kit, but not the horn kit. Someone could make the horn bracket themselves very easily by looking at the pic on the Exile website and using their coil bracket as a template.
Pic of mine removed
I really dig your turn signal locations.. just hope you dont hit the wrong kind of speed bump or something and rip those things off..
When I did mine I took the seat post, threw it in a vice and using a back and forth motion I snapped off the coil mount part of the seat post and reused it when mounting the coil where the horn was. Worked awesome and no brackets needed.
