Your pipes ever glow red?
OK, so I'm gonna rich it up a little with the PCV, but after doing a little more research it seems that it is very common for these bikes to glow a little just outside the heads. Next time you guys take your bike out for a ride, let it idle for a minute or two like I did and check your pipes for the first few inches outside the heads and see if it glows a little. I'm not talking bright red, melting metal hot, but glowing. You might be surprised at how many of you have the same thing.
OK, so I talked to Jamie at fuel moto today and asked if he could revise the map for my PCV to add a little more fuel, and told him the reason why. He said that it's absolutely normal for the pipes to glow a little for the first few inches, especially after idling for a couple minutes. He said there's no reason to remap it. I still might get a dyno-tune once the local shop gets their new machine up and running, but for now, I think I'm fine. Also talked to the dealer and they said the same thing. So did any of you guys check your pipes after ridding today? I'm curious to see if I really am the only one...
Glad to hear that the glowing is normal, 07' Deluxe stock exhaust and AC... Idling for a couple minutes, both headpipes were glowing red. I'm sure the factory settings are on the LEAN side and the stock head pipes might be thinner guage steel, letting them glow quicker.
I checked the plugs... little to no carbon build-up, clean and white with the warm weather coming, I will be getting a PC3 and appropriate map (stage 1 ) richer= cooler and piece of mind
Yes, this happened to me, and I started a thread about it a couple years ago but can't find it now. Vance & Hines Straightshots with Stage I air cleaner and remap. My pipes were red at the rear, not just the cylinder ends! Pipes were louder than usual that day, and I seemed to have more power. Don't know what it was exactly. If too lean, it solved itself. Perhaps it was the gas.
