Bar Help please
Bar Help please
So, my new Lo is great and this isn't really causing any problems.. but yet it's bothering me.. the first time I rode it I thought the handlebars were slightly crooked... I chalked it up to me being crazy... but every time I ride, I look at the bars when I'm going straight and it just seems like the bars themselves, well.. aren't straight..
So yesterday, I sat on the bike and placed my hands on the bar.. straightened up... and yes, they are definitely a little crooked.. if I look at the bars in relation with the fork bolt heads, the left side is about 1/8 inch higher than the right side... well forward I guess.. the bars are shifted forward on the left..
I'm thinking maybe when the bike was tied down in my truck when I bought it, the risers got pulled more on the left side..
Easy fix?
Easy fix?
you're a godsend on this forum.... i figured that's all I needed to do but I've never messed with bars..
Drew is correct it is usually the risers but if that doesnt do it for you it can also be the forks in the triple clamps. if that is the case you have to losen the triple clamps and twist the wheel / forks in the clamps and then tighten . Same process as the risers, put the front wheel in a corner or a chock and turn the handlebars then retighten the triple clamps
I had the same problem on my 07. Took it back to the dealer, he came outside, took a hold of the bars and just gave them a tug and pull to where they became straight. Tech said it was the cheap bushings that causes that. If ya can't get to a dealer, wedge the front tire so it doesn't move and sit on the bike and grab the bars and push or pull one way or the other. Eat your Wheaties before you attempt it.
