Head Grease
Location: in a trailer next to a ditch in South Florida
1 Post
As usual, everyone has their own preference for any lub including stearing head lub. At least those who lub their bikes as required. I prefer and use lucas grease...specifically "red and tacky #2". With it's 540 degree drop point i don't have to constantly swipe the motor. It stays in place. It is a technical blend of lithium and polymers with "anti-wear/anti seize" agents.
The key here is to fully lub the head by pumping enough grease to come out the bottom and top. There is no seal to worry about rupture. Get it full, wipe it down good and check a few times along the way until it all settles in.
It works for me !!
It works for me !!
Actually, there is no need to "fill" the neck of the steering housing. These bearings are not rotating fast nor do they generate any heat... I mean, come on, how fast are you turning your handlebars. Now that HD has wised up and increased the torque spec for the steering head, the factory grease (and I would definitely check to make sure that they greased it) will last quite a long time. Then a smidgen of grease as part of you maintenance is all that is required... marine grease tends to work great - water proof and less runny at high temps.
It works for me !!
It works for me !!
I've used synthetic red and tacky lube for rebuilding engines - but all I have is a tub of it not a grease tube ... we just give rotating and rubbing, cranks, shafts, bearing areas and such parts ... apply super thin coating as we rebuild em ... gives you a warm-and-fuzzy when you first crank them up ... I should have known to use this stuff for the head stem .. but after all these years it never occured to me ...
And .. do you think I could just replace my regular lube with the Lucas hot stuff by just pumping away until the red and tacky comes out ...
can you buy the Lucus lube you note in the small Harry-Home-Owner grease gun tube size????
***I HAVEN'T SEEN IT IN ANYTHING OTHER THAN STANDARD SIZE TUBE. I BOUGHT AN VERY IN-EXPENSIVE GREASE GUN AT WALMART AND USE IT EXCLUSIVELY FOR THE LUCAS RED. GOOGLE LUCAS !!
And .. do you think I could just replace my regular lube with the Lucas hot stuff by just pumping away until the red and tacky comes out ...[/QUOTE]
***THAT'S EXACTLY WHAT I DID AND HAVE HAD NO ISSUES. I PUMPED AND PUMPED UNTIL THE BLACK GREASE CAME OUT THE TOP AND BOTTOM AND ULITMATELY THE RED OOZED OUT BOTH ENDS AND THE BLACK WENT AWAY. THE NEXT TIME ONLY TOOK A FEW PUMPS. ANNUAL RITUAL!!
