is this normal for fuel injected bikes?
Old 04-14-2011, 08:54 PM
Hot Rod King's Avatar
Hot Rod King
Hot Rod King is offline
Default is this normal for fuel injected bikes?
Ok, not sure if this "normal" but the bike cuts out when going up inclines and around corners when the fuel is low. One time the fuel light was on and today it was just about to come on. Or should I have this checked out ?
Old 04-14-2011, 09:03 PM
BassCatcher's Avatar
BassCatcher
BassCatcher is offline
Not normal.
Old 04-14-2011, 09:04 PM
fcsallan's Avatar
fcsallan
fcsallan is offline
Not normal. Even after the light comes on it should have plenty of fuel in the pump to keep your pressure up. Not sure what could cause it unless your light doesn't come on until you are just about OUT of fuel. When your light comes on and you fuel up, how much fuel does it take?
Old 04-14-2011, 11:32 PM
Striker951's Avatar
Striker951
Striker951 is offline
Have you changed anything lately, like a tank lift or something?
Old 04-15-2011, 04:50 AM
Blk and Chrome's Avatar
Blk and Chrome
Blk and Chrome is offline
depends on if you are out of fuel or not as that is what happens when you are out of fuel. If there is still a gallon of fuel still in the tank then the fuel pump pickup is not right, you will need to take the pump out to find the problem
Old 04-15-2011, 07:35 AM
DR. V-TWIN's Avatar
DR. V-TWIN
DR. V-TWIN is offline
Former Sponsor
Maybe you have a pin hole in the fuel line in the tank for the fuel pump. I had this happen on my ride and when the gas hit a certain level it ran like crap. This is not normal for an injected bike.
Drew
Old 04-15-2011, 08:24 AM
fcsallan's Avatar
fcsallan
fcsallan is offline
Drew
Good call Drew. I forgot about that.
Old 04-15-2011, 08:44 AM
Hot Rod King
yeah nothing changed to the tank or anything. Only thing recently which has been a while is that I had it tuned and a pc3 installed. When the fuel is low and I've filled up, it took right at 4 gallons. When its full or even half full, it does not do this. Crap, gonna have to have it checked out
Old 04-15-2011, 08:46 AM
fcsallan's Avatar
fcsallan
fcsallan is offline
I think Drew hit it on the head. The fuel pickup hose in the tank can crack or even have a pin hole in it that can cause this. As soon as the hole is exposed by the fuel level dropping below it, it will suck air and cause the injectors to lose pressure. Not a very difficult fix. Just time consuming.
Old 04-15-2011, 08:49 AM
KumaRide's Avatar
KumaRide
KumaRide is offline
Sounds like pin hole in tank fuel line. Very common. Here is how to check it.
https://www.hdforums.com/forum/softa...pin-holes.html
Quick Reply: is this normal for fuel injected bikes?
