is this normal for fuel injected bikes?
Old 04-15-2011, 09:24 AM
stevevfd's Avatar
stevevfd
stevevfd is offline
If you take off the gas cap, turn the ignition on, and hit the run/stop without hitting the start button, you probably will hear gas splashing around. That's the gas spraying out of the pin hole in the line. I replaced mine with Gaites submersible fuel line (About $40 for 2 1 foot pieces) and fuel injector clamps and it's running like a champ. Took me about an hour to do.
Old 04-15-2011, 12:59 PM
STLFLSTF_Mike's Avatar
STLFLSTF_Mike
STLFLSTF_Mike is offline
Hey Hot Rod, I had the same thing happen the other day. I was leaning hard on a curve and the bike sputtered. Looked at the fuel gauge and I only had one LED light on (flush fuel gauge) stopped at the gas station on the next corner and I pumped 4.6 gal into a 5 gal tank. Hasn't happened again so I'm assuming that it was because of low fuel.
Old 04-15-2011, 02:00 PM
Hot Rod King's Avatar
Hot Rod King
Hot Rod King is offline
It happens on slight inclines too which is why I thought low fuel was causing it to cut out/sputter. But everyone here says that a injected bike should not being doing this regardless of turns/uphill. I think Im gonna have it checked out just to be safe. Thanks man
Old 04-16-2011, 07:26 AM
chiefe's Avatar
chiefe
chiefe is offline
I had a similar problem, sputtered when fuel was low and when bike was inclined. Guess what pinhole in the fuel inlet line. Think about, as soon as the bike is inclined the fuel flows towards the rear of the tank and the pump starts sucking air. Wasn't a hard fix at all, a small piece of fuel hose, a couple of clamps and about an hour of your time.
Cheers!
Old 04-16-2011, 07:37 AM
DR. V-TWIN's Avatar
DR. V-TWIN
DR. V-TWIN is offline
Former Sponsor
As soon as the fuel line is not completely submerged in gas, the fuel line for the fuel pump starts to suck air which explains why it does it on an incline.
Drew
garyls
05-04-2018 08:22 AM
cripple
12-21-2012 04:35 PM
knucklehed
03-29-2012 08:58 AM
JonnyB
05-22-2010 10:03 AM
dhc8guru
05-24-2008 02:04 AM
Quick Reply: is this normal for fuel injected bikes?
