I'm trying to remove my outer primary cover. I have all 12 of the bolts removed, but it's not coming off. I tried using a rubber mallet along the seam between the inner and outer primary, but that hasn't worked either. Anyone have any ideas?
I haven't drained it. The drain plug is completely stripped. I want to take the outer primary cover so that I can get the stripped plug out. I know that it is going to make a big mess, but I don't have any other options. I removed the clutch inspection cover and tried yanking on that while tapping, but it still didn't come off.
Not trying to insult your intelligence but is your inspection cover still on? cause two of those bolts go all the through to the inner primary.
Don't worry about insulting my intelligence. I prove to the world everyday that I don't know ****. Yes, the inspection cover is still on. I will remove it and try again. Thanks!
