Console kit HD 71208-07 (pics)
Before I start to take stuff apart. I did search the forums but with not much help. Thanks in advance for any help. So at a swap meet a couple weeks ago I pickup the main part of the HD Console Kit (pn 71208-07) for a very good price.
some of the parts of the kit were gone like the bezel. I went to the HD site and downloaded the pdf directions/parts list http://www.harley-davidson.com/en_US...ts/-J04166.pdf
Based on the parts list I order the rest of the pieces I need. All the part numbers match. Looking at the parts I am unsure if the bezel will work (it is the correct part based on the pn in the HD directions). On the bezel there is a threaded winged flange (not sure what it is exactly called). Basically threaded screw hole with wings. I am confused on how this is supposed to line up with the main console…there is a notch cut out of the end but when I lay the bezel on and it does not line up correctly (other holes line up)…half the screw hole is on the tip of the console… Am I just missing something?--or does it all just go together once the speedo gasket is put on?
I have rechecked all the part numbers and they are correct…it looks like the flange piece has to line up on the cut out on the top of the console.
Anybody who has installed this kit or has it on their bike…advice or a pic of the top part of the bezel/console would be great.
I am looking at picking up that console too, please post some pics when you're done! Am I mistaken or does the HD parts guide say that the console is not compatible with the skull gas caps...like it is in that pic. Sweet looking console-does it come complete when purchased as a whole? (I mean with new ignition switch or do you reuse the existing?)
Winged Bezel
So does the winged part go completely on the outside of the console or does it sit on top of it (when I lay it on there---if you look down thru the threads the edge of the console falls in the middle of the threads)?
Flange
You wouldn't happen to have any picks of it?
thanks
Just sits
Will do. Just seems odd it would be designed like that. Thanks Ice.
Mr_Taipan
08-06-2015 02:01 PM
