What he said! I sprayed simple green and let soak for a minute and the scrubbed the simple green with Mr clean erasers, worked great. The only thing I found that worked better was changing my tires to Black Walls!
[sm=funnypostabove.gif] But really , I have the problem with the back tire , WWW `s are brand new getting a yellowish ring on the outside of the white wall on both sides. Will Simple Green take that off ? Is there anything else I can use ?
Magic erasers work well. Like mentioned before, spray with simple green, let soak for a minute, then use magic erasers as directed and they will do a great job. I really did change to Black walled tires!
