Primary cover removal.
Hey all, new to the forum. I'm considering powdercoating my primary cover(09 crossbones) and I have a couple questions about the removal(the bolts are pretty straight forward but thanks in advance for that one)
lol. I build and work on my own turbo snowmobiles so I'm no stranger to tearing into machines.
Just a couple questions.......
Is there oil contained in the primary chain housing cover that I am gong to be removing?
Any surprises with removing this cover or is it just straight forward, pop it off and bolt it back on?
Thanks in advance
Sam
![Smile](https://www.hdforums.com/forum/images/smilies/smile.gif)
Thanks in advance
Sam
Do you have a manual? There is a sequence to removing and installing the bolts on the primay cover... there are also two small round gaskets with sticky backs to hold them in place when you are putting the cover back on make sure you look for those when you remove it to make sure you don't over look that. Nothing hard I tape up a large plastic rubbish bag under the primary on the frame cause when you pull it off there will be some oil still dripping makes for a cleaner job.
you might not need to remove teh floorboard..if it's anything like the Lo, all I had to do was just loosen the 3 bolts that hold the floorboard on, and that was just to be able to tilt them enough to remove one of the "long bolts" from behind it.. if you have a heel-toe shifter (idk if the xbones does) the heel part will have to come off, but other than that it's not bad..
oh, invest in a new primary gasket, and there's a drain plug to get most of the oil out underneath the primary.
Procedure is probably in your owners manual as well. What everbody else said particulary, follow the sequence and DO NOT overtighten the screws on reinstallation. There is a torque value for them and it ain't much. If you don't use a torque wrench (which you should), a nut driver w/torx bit or a 1/4" drive is plenty. Read some of the recent stripped screw threads to reinforce that if necessary. It's not rocket science. You probably should cover the primary while your cover is out for powdercoating, just a good practice.
