question about screamin eagle slip-ons
just received my new screamin eagle slip-ons (part # 80497-07) for my 2007 fxst. while looking at them, i noticed that there were teo bolts in output end, very similar to the old screamin eagle II's with removable baffles. question is, are the baffles really removable as the II's were, or are the bolts in place more for show. i put the slip-on's on, and not real impressed with the sound. would like to make them louder. any info will be appreciated
RE: question about screamin eagle slip-ons
The bolts on the end are a torx "securty tamper proof" bolt. They come out pretty easy by just using a 10mm wrench on the nut inside (stick a eyeglass screwdriver in the torx head if it moves). When you get the baffles out hacksaw the closed end off. I also added a set of thunder monster baffles in the headpipes before the muffler went back on. Sound is good, not to loud. It does make it run leaner but the PC 3 coming in the mail will fix that. I've also done the HD download and the SE Air Cleaner. The bike runs a lot better then it did stock, even running lean, so I'm hoping the PC 3 will finish the package.....for now.
I just purchased the 2007 SE slip on's and just out of curiosity I removed the (2) bolts. I tried to remove the baffle to the pointI was concerned the much more force would create damage. Is there a trick to removing them or did I not use enough brut force?
Yes they advertise that they are not removable. I spoke to a private shop owner today and he said removing the baffle wasn't difficult. Af'ter removal of the keyed bolts he attaches a slid hammer to the ID of the pipe and pulls it out. I'm due for my 1,000 mile service at which time I'll have a Stage I air cleaner kit and remap done.Once I get it back I'll try removing the baffles. Oldpanrider was sucessful at it and happy with the results.
sinbadjmu
I'm just learning about this stuff but from my understanding installing a stage I air cleaner kit requires a Re-map. If not you risk the engine running to lean. So as long as you have had it re-mappedwhich increases thefuel mix playing around with the pipes is not a problem.
I purchased the SEII's for my Heritage, however over time i found that I wanted a louder sound from my pipes. If I were to do it again, I wouldvewent with some V&Hs or some other straight pipe. Since i dont have a time machine and in the interest of dollars I have opted for Big City Thunder baffle replacements. They are about a $120 and should increase sound and hopefully perfomance. If and when I leave the God forsaken land of AFghanistan I will get them installed and repost my thoughts on the modification.
Here is a picture of the stock baffle (top) and the aftermarket baffle (bottom.)
