200/55 17 on a Deuce
Old 03-19-2011, 08:24 AM
cruiser73's Avatar
cruiser73
cruiser73 is offline
Default 200/55 17 on a Deuce
I have a 2002 Deuce that I am currently running the stock rear wheel and the 180/60x17 Screamin Eagle tire on.
I would like to run the 200/55x17 tire that the 2006 and up Softails are running.
I've seen posts where people change rear fenders and run a 200 tire, usually an 18" on an aftermarket wheel.
I want to keep the stock rear fender, and either keep my stock Deuce wheel, or switch it out to a later model Softail Custom (FXSTC) wheel and pulley (which used the 200/55x17 tire).
Has anyone done this? And if so can you break down for me what I would need to do it?
Thanks!
Old 03-19-2011, 09:00 AM
Sgt_Jim's Avatar
Sgt_Jim
Sgt_Jim is offline
If i'm not mistaken, i think i've read somewhere that to go to a 200 tire, you need to change the pulley and belt to a narrower belt setup, and change your spaces (obviously).. as for doing anything to the swingarm/fender, I'm not sure about that
Old 03-19-2011, 05:27 PM
cruiser73's Avatar
cruiser73
Thanks for the reply.
I know about changing to the narrower pulley and belt. Its all the other clearances that I am wondering about. Fender, swingarm, caliper, etc.
Any help is appreciated!
Old 12-25-2020, 04:56 PM
Innigray's Avatar
Innigray
Innigray is offline
Default 200
Merry Christmas I've sent you PM cheers
Old 12-25-2020, 07:40 PM
kiwideuce's Avatar
kiwideuce
kiwideuce is offline
you need the 07 night train narrower belt and pulley, probably a pulley spacer from Drag Specialties, you work out the width pulley after wheel is on the bike with new pulley
you move the pulley to the position were it clears the tire on one side and swing arm on the other, i have this on my deuce and an 18x5.5 rim i did it along time ago i think
the 18 rim was so you didn't have an issue with the caliper ,a wider 17 rim would contact caliper the 18x5.5 clears the caliper
Old 12-25-2020, 10:09 PM
Iron lHorse's Avatar
Iron lHorse
Iron lHorse is online now
Received 2,675 Likes on 1,268 Posts
Have you ever thought about just converting a Rocker into a Deuce . You’ll get a 240 rear tire and just have the change the tank Console and front fork lowers .
And you’ll also benefit from the Rockers larger motor and a six speed transmission .
Old 12-26-2020, 04:45 AM
Iron lHorse
This is a 10 year old thread
Old 12-27-2020, 03:25 PM
cruiser73's Avatar
cruiser73
Thanks for the recent replies. I am still watching the post!
Old 12-27-2020, 06:33 PM
Iron lHorse
LOL , Well how are you doing with this project ?
JMo
08-19-2016 07:05 AM
GolfWrench
11-13-2014 04:51 AM
Half-Fast Deuce
06-11-2013 06:13 PM
jdsmitty10
03-13-2011 07:24 PM
deucn2
04-26-2009 10:14 PM
Quick Reply: 200/55 17 on a Deuce
