PC III usb map m805-037
Just got my PCIIIUSB in the mail today. I was looking at the available maps, and see the following:
MAP M805-037
2001 Softtail
Cycleshack Tapered slip-ons
Screamin' Eagle air filter
Stage 1 ECM
My question is the following: I have the same setup as above, only on a 2006 Softtail, not a 2001. Is this map OK? Anything I should tweak for the difference from 2001 to 2006?
-Rob
MAP M805-037
2001 Softtail
Stage 1 ECM
-Rob
I sent a tech support help request in to DynoJet...they got back to me quickly...here is their response. I'll give it a try as soon as I get the unit installed (likely this weekend).
On the 2006 Model bikes, Harley changed the fuel injectors. With that I would actually recommend you use map M805-221. It is for a different brand of slip on but will work much better than the M805-037 map.
*2006EG*
04-27-2008 03:43 AM
