Have a clear goeey liquid dripping off of my Primary
Old 03-16-2011 | 06:01 PM
JPL's Avatar
JPL
Default Have a clear goeey liquid dripping off of my Primary
What could it be?!?!?!
Old 03-16-2011 | 06:03 PM
murd's Avatar
murd
...stop drooling over your bike.
I could have said something else, but I kept it clean.
Old 03-16-2011 | 06:08 PM
JPL's Avatar
JPL
hahahahahaha, fair enough... But seriously, what could be dripping from the bottom of my primary.. have no clue what it could be..,.
Old 03-16-2011 | 06:45 PM
im's Avatar
im
To better assist:
Did not see year, model and miles to better assist.
Possible isolation of exact area would help paint mental picture to question.
example: inner primary near belt ,shifter shaft or outer primary near floor board torx drain bolt.
Old 03-16-2011 | 06:48 PM
DevilSperm's Avatar
DevilSperm
Grasshopper guts!
Old 03-16-2011 | 06:49 PM
Primo's Avatar
Primo
Could be (among other things) :
A: Primary fluid from drain plug.
B: Primary fluid from Stator plug.
C: Transmission fluid from shift shaft seal.
Don't ask me how I know.
Old 03-16-2011 | 07:01 PM
JPL's Avatar
JPL
2009 Fatboy 5,000 miles. recently just installed the kuryakyn inner primary cover as well as the battistini derby cover maybe its something wrong I did when installing the derby cover? i thought it was just an easy swap from the stock one.... have been riding for 3 days now and just today it started to leak... its leaking right under the derby cover. Hope all of this information will help you guys help me! thank you
Old 03-16-2011 | 07:06 PM
Sgt_Jim's Avatar
Sgt_Jim
probably got a bum gasket.
Old 03-16-2011 | 07:16 PM
Primo's Avatar
Primo
Not sure on the softies but on the touring bikes the derby cover gasket only works in one direction. Maybe yours got put in backwards?
Old 03-16-2011 | 07:22 PM
Jackie Paper's Avatar
Jackie Paper
Wipe it off good and watch. Bet it's the outer primary cover. Just a guess but when I had mine off I was amazed how warped it was. You need to start in the middle and slowly do top and bottom working out. I did it in about 3 steps before I got to torque. It would be very easy to not get it down flat. Harley's gasket is 3 layer with a slight v in it. I still used just a smear of RTV. I torqued by fill but I work on this stuff all the time. I would not normally think of any fluid in a Harley that is clear goeey liquid. Most all in mine is black oily.
Quick Reply: Have a clear goeey liquid dripping off of my Primary
