crossbones 150 front
Old 03-16-2011 | 06:09 AM
brettnbama's Avatar
brettnbama
Default crossbones 150 front
I saw that thread a while back, but the thread starter hasn't been online since December. Has anyone else run a 150 on the front of the Cross bones? What width rim would it need to be? It looked in his post as if he was on stock rim? Anyone know how it rides/handles? I am thinking about making this swap when it comes time for new rubber.
Old 03-16-2011 | 06:22 AM
dcgray2's Avatar
dcgray2
Default Any help?
I'm asking a similar question here about an Avon on a Fatboy here:
https://www.hdforums.com/forum/softa...boy-tires.html
Don't know if that helps, the MT90 thing throws me off.
Old 03-16-2011 | 08:18 AM
asg13's Avatar
asg13
I read that post as well...I do remember him saying stock wheel and he had to modify the fender a bit..maybe just bending it out..
good luck i would like to know as well
Old 03-16-2011 | 08:27 AM
brettnbama's Avatar
brettnbama
you know, if someone would make some fender reloction brackets for the crossbones, they would probably sell pretty well. I know they have them for touring bikes and stuff, the front fender thing really limits Crossbones owners. I want to change to a 21" front wheel, but don't want to not have a front fender.
Old 03-16-2011 | 08:30 AM
brettnbama's Avatar
brettnbama
Does anyone know what the width of the factory tire is? Like said above the M90 designations screw with me...also, this may be a silly question, but how does the bike get the speed and odometer readings? Is it based on tire rotation? Would changing the overall diameter of your wheel/tire affect your speedo/odometer? It can with certain cars which is why I ask.
Old 03-16-2011 | 09:20 AM
XARAN's Avatar
XARAN
I'm following this as well. I like to go 150 on my front at the next tire change
Old 03-16-2011 | 01:34 PM
ITZ4me515's Avatar
ITZ4me515
I also would like to change to the 150. It looks like he used a Dunlop tire for the front, as the tread pattern seems to match.
I'm pretty sure that the speedo runs off the transmission...I know that it doesn't run off the front wheel...try doing a burnout, your speedo will show how fast the rear tire is moving.
Old 03-16-2011 | 01:43 PM
ITZ4me515's Avatar
ITZ4me515
The stock MT90 is 130mm wide. Actual width 134mm.
I am thinking about going with the Metzeler ME 880 Marathon 150/80-16 as it's overall size is 153mm. And they make a front tire for it. Most 150s seem to be rears.
Old 03-16-2011 | 03:28 PM
cammy's Avatar
cammy
6th Gear
Avon do 150 tyres for the front in 16'' you will need a rim 3.5 inch wide
Old 03-16-2011 | 04:11 PM
dcgray2's Avatar
dcgray2
Default Tire sizes
According to the specs the 150/80 Metzler 880 is slightly larger diameter 26.73 vs. 26.5 and slightly wider 5.98 vs 5.9 than the 150/80 Avon Cobra AV71.
Edit: Sorry just realized thats for the 17" tires
Quick Reply: crossbones 150 front
