what is the best cams for 103
i have stag2 103 upgrad and it comes whit cams 255
i have the 255 cams and i didnt like it because it give a lot of power from low RPM and when it go's 4500 RPM the power go's down like a rock
so i need cams that gives power midrang and topend
so plz
so plz
so plz
so plz
Best Cam
i have the 255's on my 103. Yes, it makes huge torque at low end, but does not run out of power at higher rpm's as you describe. i also have a few other mods that might affect this also.
Pat in Tennessee
2008 Rocker C- FXCWC
SE Stage II 103 Cu. In. Big Bore Kit (1690 cc) 3-7/8”
SE Pro 4-3/8” Stroker Flywheel and Rod Assy.
SE Pro (MVA) Heads
SE Pro 58mm EFI Throttle Body
SE 255 Cam (Torque)
SE Roller Rocker Arms
SE Roller Tappets
SE Valve Spring Kit
SE ST Spark Plugs
SE Pro Tuner Kit
Vance and Hines Big Radius Exhaust
SE Stage 1 Air Cleaner Kit
SE Hi Flow Billet Air Cleaner with 103 Medallion
FXCW Luggage Rack Kit (Now Chrome Plated)
FXCW Seat
Custom Fabricated Sissy Bar (polished stainless steel)
H-D VRSC Sissy Bar Pad
H-D Flames Footpegs
H-D Chrome Voltage Regulator Cover
Custom Stainless 1” Tank Lift
Kuryakin ISO Grips
Comagination Head Light Modulator
Scorpio SR-i901 Active Security System
H-D Windshield
H-D Chrome Shift Rod Kit
Pat in Tennessee
SE Pro (MVA) Heads
SE 255 Cam (Torque)
SE Roller Tappets
SE Valve Spring Kit
SE ST Spark Plugs
SE Pro Tuner Kit
FXCW Seat
H-D Flames Footpegs
Kuryakin ISO Grips
H-D Windshield
