Started cutting the fender but need some input please
Fat boy rear fender arrived today and this thing is in pretty rough shape, no matter cause I'm cutting it down around the damage. Chopped it down to the length that I want but now I'm not sure if I should cut the radius cut I have laid out in tape? If so what the heck can I cut that with, I don't have a plasma cutter.
Also fender on the bike doesn't look right but I'm assuming it will look a ton better once painted and the bike is back on the ground so the tire will fill up the gap nicely.
By the way, I cut the excess off with a dremel tool and a cut off wheel.
Just use tape to draw out the cut line bro, and trim the sides but your going to have to add a curve so that it looks clean when the sides turn into the center
