Started cutting the fender but need some input please
When i chopped mine i did the cuts with a dremel and then place a paint can lid down to make my lines for the corners. Once that was done i did 2 straight cuts and used a grinding bit to smooth the corners and bottom edge that runs under the fender struts. I will try to get some pics for you tonight.
Thanks,
next up is to take it for sand blasting and paint. Waiting on the alloy art fender strut mount signals from the good dr. v twin, deciding on a side mount license plate and I should be good. Finishing up the lowering kit for the front end this weekend hopefully and it all goes back together. Hope the weather starts breaking.
J51
J51
J51
Thanks alot. Really not much to it once you get up the nerve to actually start cutting. It also helps to have a fender that you don't care about. Spent $40 on it so if I screw it up it's not as bad as if I were to screw up my stock fender.
J51
