HD oil cooler kit and changing the oil filter
Ok I have searched and tried to look at all the pictures I can, but I cannot find a straight answer. My question is about need to the remove the crank sensor to remove the oil filter after the installation of the oil cooler and the oil filter adapter. Some say yes I will need to remove it, others say no, some recommend a shorter filter and some even say to buy an offset adapter…. ughhhh sometimes too much information is worse than none at all.
So once and for all will I need to remove the crank sensor to change my standard size chrome HD oil filter after installing this kit???
In case it matters
09 Fatboy
HD part # for the cooler 26157-07
thanks
Rich
In case it matters
09 Fatboy
thanks
Rich
