I believe in the spark plug being so important in the performance of an engine that I even go so far as to "tune" the plugs when I install them... set the gap side of the plug toward the valve opening so that the fuel mist is not blocked at all from the spark.
Very interesting reply...and sounds "logical".
How do you set the "gap side" toward the intake valve?
It is technically called Indexing -
From the NGK site "Indexing refers to a process whereby auxiliary washers of varying thickness are placed under the spark plug's shoulder so that when the spark plug is tightened, the gap will point in the desired direction."
Thats sort of what I do for my Hot Rods. But you have to buy 12-16 plugs so you can index them to get 8 that line up right. PIA but worth it.
