quick football A/C insert question
Old 03-06-2011, 10:06 AM
DeluxeW00kie's Avatar
DeluxeW00kie
DeluxeW00kie is offline
Originally Posted by HoggyMtnBreakdown
+1.
Looks better because the trim ring is recessed in, as opposed to being just stuck on and you don't have to worry about ruining the trim ring when removing it.
this is the samething i did with mine
Old 03-06-2011, 10:41 AM
Dawg Rider's Avatar
Dawg Rider
Dawg Rider is offline
A lot of Dyna riders have done that after member WS6 Formula started it a few years ago. The one in my sig pic is mounted on a plain round cover, or it can be run open. (Edit: Mudpuddle did these for a bunch of guys a couple of years back, but he no longer does them for others)
Here's a couple of threads (the second one with video):
https://www.hdforums.com/forum/dyna-...?highlight=ws6
https://www.hdforums.com/forum/dyna-...echroming.html
Also, member Pig in a blanket stuck just the trim ring on a round chrome cover for a similar effect.
Old 03-23-2011, 08:48 AM
Sgt_Jim's Avatar
Sgt_Jim
Sgt_Jim is offline
Default A/C Insert carved out. huzzah.
from the typical football cover:
to a nice clean cutout:
I followed these directions up until where you start cutting:
https://www.hdforums.com/forum/2909122-post642.html
since I don't have a die grinder, I used a Dremel tool @ 30,000RPM with a reinforced cutting blade, which ran through the aluminum of the cover like butter.. and since I don't have an angle grinder, or a drill press (though my neighbor does but he was at work).. i filed down the edges and evened it all out by hand.. it actually was pretty easy and took maybe 2 hours total.. since i was doing it all by hand and all.. then shot the edges up with some close-as-can-be color matching engine enamel to prevent rust.. i thought she turned out quite good actually..
edit..Ps thanks for the link Dawg Rider..
Old 03-23-2011, 11:32 AM
jargon51's Avatar
jargon51
jargon51 is offline
Looks awesome. I think I'm going to start on that one tonight. What air filter do you end up using when doing this modification? Do you have a part #
Thanks,
J51
Old 03-23-2011, 11:39 AM
Sgt_Jim's Avatar
Sgt_Jim
Sgt_Jim is offline
Im running the Arlen Ness Big Sucker Stage I, and its just a standard K&N filter on there, PN HD-0800
http://www.amazon.com/HD-0800-Replac.../dp/B000FGCYT4
and as long as you have a steady hand, the mod is really easy to do.. the aluminum cuts like buttah..
Old 03-23-2011, 11:48 AM
jargon51's Avatar
jargon51
jargon51 is offline
Sweet, thanks!
Old 03-23-2011, 02:09 PM
prostar's Avatar
prostar
prostar is offline
I would spray paint the bolt Satin Black also
Old 03-23-2011, 03:18 PM
Sgt_Jim's Avatar
Sgt_Jim
Sgt_Jim is offline
Thought about it.. but I kind of like how it stands out like that..especially since throughout the rest of the bike are the aluminum bolt heads
Rail
03-28-2011 01:17 PM
creep1
02-21-2010 06:53 AM
creep1
02-20-2010 02:59 PM
pistol_pete10
02-25-2007 07:32 PM
deuce31
12-17-2006 12:40 PM
Quick Reply: quick football A/C insert question
