HD Bags Bracket Removal/Replacement?
Ok as many of you may know I posted a thread about what types of quick disconnect options were there for HD bags on a Fatboy....many great replies and exactly the info I was looking for....now to my next issue...I have these bags listed below....HD brand Hard Leather Covered Bags Part# 53061-00B...on page 246 in 2010 HD dream catalog.....now my issue is what do you do to remove or alter or whatever to use these bags with the factory oem bag mounts on them as you will see in the pictures below?? I would like to use some sort of quick disconnect system....I prefer the easy brackets so they remove in seconds AND LOCK too.....really need your help with this one guys....what do I do now?
Thanks and please don't hesitate to email or post up any help you can give me is greatly appreciated!!
Thanks...
William
Here are my bags HD Part # 53061-00B
And here are the brackets HD decided to attach on them....they look like they are heavy rivetted on there....
Thanks...
William
ok so you want to get the brackets that are riveted on there now off the only thing that comes to mind is to carefully grind the button heads off but before you do that you may want to see if they will not fit up to the brackets you want to use if not grind them off slowly so they dont get too hot and melt through the bags and fill the extra holes with black silicone. Thats the only thing that comes to mide
Grind them off. You will need to space out the lower paortion ogf the ez bracket between the ez bracket and bag. The ez bracket needs to sit flat/flush with the bag when it is mounted.
If it were me, I'd sell those bags and get some nice, larger bags that will fit better with ez brackets. You can never have too much storage space and will appreciate the larger bags. All this depends on what bike you are talking about and the pipes you have.
If you really want to keep those bags if you use the EZ Brackets with the HD Bags they will be about 3" away from the bike on each side at the bottom of the bag and about 2 " away at the top due to the spacing of the bracket and the design of the bracket. Instead of EZ Brackets look at the Boss Bags Quick Detach Brackets for Heritage Bags I think those would work for the HD Bags, but call them to be sure or look into Ghost Brackets from Cycle Vision for a quick release.
If your set on EZ Brackets the Hog Deluxe Bags are the way to go using them since they are decigned to hide the bracket and move the bag closer to the bike
Below are some Osprey Bags I used to have mounted by EZ Brackets (your HD Bags will be out further at the bottom since you have to space them to keep them vertical) and my new Boss Bags with Phantom Brackets . You can see the difference is how close they mount to the bike.
AmericanMuscle
09-20-2012 05:38 AM
Northern B
06-01-2010 05:02 PM
