FLSTFB - A Tire Pressure Discussion
There is a "max cold psi" rating on the sidewall of every tire... since there are now so many after market tires available for almost all makes and models of bikes, most, if not all, motorcycle tire manufacturers now recommend running their tires within a couple pounds of "max cold inflation psi" to get the top performance out of the tire. The psi listing in the owner's manual is only meant for OEM tires based on an average rider and that person's average riding style... of course adjustments need to be made for the variables of the person/persons riding. ie two up... tour pack weight... day rides vs touring.
![Icon Mad](https://www.hdforums.com/forum/images/smilies/icon_mad.gif)
![Cool](https://www.hdforums.com/forum/images/icons/icon6.gif)
![Icon Woot](https://www.hdforums.com/forum/images/smilies/icon_woot.gif)
JMHO
![Icon Dopey](https://www.hdforums.com/forum/images/smilies/icon_dopey.gif)
Recommended Pressure
If you don’t know the proper inflation air pressure for your tires, what do you do?
Easy. Check at one of the following places on your vehicle:
- In the vehicle owners manual.
- On the vehicle’s door jamb. (Often, a vehicle information placard is located on the door jamb along with the recommended tire inflation pressure.)
- Inside the fuel hatch filler flap. (In some vehicles.)
- The glove compartment door. (In some vehicles.)
- But NOT on the tire. The inflation pressure shown on the tire sidewall is only the maximum tire inflation pressure. In most situations, the vehicle manufacturers recommended tire inflation pressure is shown on the vehicle placard. However, on some older vehicles, the recommended pressure listed by your vehicle’s manufacturer may be shown as two numbers: One for city speed driving and normal load and one for highway speeds and/or maximum capacity vehicle load. Be sure to inflate your tires to the recommended inflation pressure for each type of driving situation.
Faasted is correct as to where to find the info, but I would add the these are just that; ' RECOMENEDED ' Different pressures for different conditions, as has been noted in previous posts. It has not been mentioned that tube type tires are different from tubless . . . . ![Icon Exclaim](https://www.hdforums.com/forum/images/smilies/icon_exclaim.gif)
JMHO
JMHO
![Icon Toast](https://www.hdforums.com/forum/images/smilies/icon_toast.gif)
JMHO
JMHO
I have yet to see legitamate recommendations to run at max sidewall pressure.
1 Post
Don't exceed the maximum pressures listed on the sidewall.
To figure out the proper pressure, you really need to take it's temperature. The purpose of proper air pressure is to get the rubber in the proper temperature range. Too cold or too hot and the tire won't stick to the road as well. Too hot will also accelerate wear.
Reduce the pressure to increase temperature; increase pressure to reduce temperature.
This is why increasing the pressure helps get more mileage out of a tire. But don't increase it so much that the tire doesn't get warmed up enough.
This also means that it is all dependent on how much weight you are hauling, the kind of riding you do, the ambient temperature.
But most of us don't have a tire pyrometer. In general, the 10% rule will get us in the ballpark. The idea is that the difference between cold and hot tire pressure is about 10%.
On a local service tech's advise - guy with Harley-Davidson training certificates all over the wall - I run 40 and 40 on my FLSTC. The ride is smooth and steady, not harsh or bumpy. Harley's manual recommendation is always low. His experience shows that the tires wear faster at lower pressure, generating sales for the Moco. Hmmm
My FLSTC must be different than yours. It don't like 40 in the front.
Maybe I am too picky. I don't like feeling all the tiny imperfections in the road.
Trial and error, forming your own opinion, is sometimes better than taking one man's word and considering it golden.
