Power Commander V Crossbones Install
As soon as it warms up few degrees, I'm headed out to install the pcv..
Now, mine has a badlander seat..so I'm not sure what that means as far as the room to fit everything...also, I don't have the deep ecm tray..
Any tips would be helpful..
As far as maps..
I have rush slipons with the 2.25 baffles..stock a/c..for now
the closest map I see is for SE slipons with stock a/c and rev extend..
any opinions?
thanks for any help
John
edit..
Cellphone vid..
End result
http://www.youtube.com/watch?v=8-BLN..._order&list=UL
As far as maps..
any opinions?
thanks for any help
John
edit..
Cellphone vid..
End result
If you follow the line up from the rear sensor you can feel the connector. You should be able to feel the button bump to release it. When reassembling make sure you hear the click to know it is fully connected. It is a bear to find, lying down and looking up as you feel along the wire might help.
space
I've got mine all crowded in there and don't like it much. Looks like a rats nest. I'm going to get one of those new lithium Ion batterys that are smaller with more CCA's and move some wiring down in the extra space. Reminds me of my 80FXWG wiring. All the breakers and wiring was right next to the gas tanks. Daaa.
