football to round a/c cover, not Stage 1
Guys, without going Stage 1 and investing in hi-flow and fuel management, can the stock oval filter be replaced with a round K&N that will take a nice round a/c cover? Would like to shed the football, but don't want to invest in Stage 1 yet. Thanks.
Something like this, a used complete Crossbones AC assembly may do it for you. Not sure if he still has it but its cheap and you may be able to put a different cover on it.
https://www.hdforums.com/forum/softa...er-set-up.html
Just get the filter
Here's a football, with a K&N round behind it mounted to a chrome screaming eagle filter backplate.
You don't have to change anything else if you just want more air. The chrome backplate is $45 and the filter is about $65. More air, more power.
I do have a V&H fuelpak, but that's needed because of the true duals, and V&H ovals.
Not entirely true. It's not like you are giving it a big increase in air flow. The stock system will adjust itself in that case. The sensors will handle it if adding either slip ons or a high flow ac but not both at the same time. There are plenty of discussions on this forum regarding this subject.
